1995 LS400 Very Low Idle
Hey all, I値l start with saying I have done some searching and now I知 stuck..
My LS400 idles at about 100-200 rpm once It has been fully warmed up. The car never dies, but Khar never hesitate, I just wanted to get your thoughts?
check TPS to make sure it's not loose? try adjusting it a little back and forth to see if idle rpm changes? squirt some carb cleaner around your vacuum lines (at low idle) to see if you have a vacuum leak somewhere
take a look here as well https://www.clublexus.com/forums/ls-...d-problem.html
also here are results for "LS400 low idle" search:
https://www.clublexus.com/forums/sea...rchid=20982397
yeah, it's a common problem
