Location and removal of neutral safety switch
Hey all,
I believe I have narrowed my no start of my 92 ls400 to being either the ignition switch, the ecu, or the neutral safety switch. I've replaced the ignition switch and replaced my ecu caps. I am now trying to find and diagnose the nss but am having trouble finding it. There is very little information on the subject for this car. Can anyone help me find the nss location and provide direction on how to remove it and test it? I completely dismantled my center shiftconsole and shift **** trying to find it. I can see through the interior down into the transmission area. The shift piece is connected to a metal rod via a cotter pin. My car is lowered so getting underneath and easily looking around is hard. Help please! 😊😊 Thanks everyone
I'm guessing your starter is not working and you're narrowing it down...
Before going any further, on my '91, I was once convinced of a NSS problem. Then just as I was about to jack the car up and take it out / clean / replace / etc., I checked fuses. There is a 7.5A fuse for the "STARTER" in the driver's footwell fuse panel. Mine was blown somehow. Replacing it fixed my problem.
As I recall the NSS would have been accessed by jacking the car and then finding it attached to the AT somewhere obvious. Luckily I've never actually had to find it. Good luck.
I thought it was the starter before so I took it out and had it tested and rebuilt. I can jump the starter relay and it cranks every time. This was where I've been stuck for awhile because I'm not getting any spark and figured that the ignition switch primes everything including the ecu. I've tested all wiring through the ignition system and it dead ends at the ecu. Also I've figured that the nss is telling the ecu not to start the car because it's faulty. If I turn my key to on my cooling fans don't turn on either. They used to always automatically turn on with the key in the on position.
Also, BTW at over 200k miles now, my '91 is working great on its original starter, starter relay, ignition switch, and ECU with replaced capacitors. That fuse and the battery are not original, everything else is.
I agree the lack of spark adds a twist here. Hopefully the circuit diagram can let you figure out how a single problem somewhere would be causing the symptoms you've got.
10th Gear
Check under glovebox
etj1085
14
02-28-16 02:21 PM
Mooglide93
01-29-12 02:14 AM
