Suggested suspension parts replacement
Old 06-03-19, 11:41 AM
kambam3627
kambam3627's Avatar
Default Suggested suspension parts replacement
2000 platinum, 180K. I bought this car and it’s fine at the start, then the front brakes started shaking Everytime I brake, rotors as many said. But ever since then the front suspension takes bumps so bad, to the point I feel it in the steering column and it shakes like mad,My 330K LS drove way smoother than this one..... anyways does anyone have any suggestions on what I could replace in order to make for a more smooth cushion like ride that I think most of us desire here.... thanks.
Old 06-03-19, 11:58 AM
Stroock639
Stroock639's Avatar
strut rod bushings, control arms, ball joints, and sway bar bushing (toyota calls this bush, stabilizer
the sway bars are by far the easiest and cheapest to replace
https://www.clublexus.com/forums/ls-...-bushings.html
Old 06-03-19, 06:22 PM
kambam3627
kambam3627's Avatar
Stroock, thanks for the input. I’m probably gonna do the sway bar and control arms first. Kind of on a budget of 500$
Old 06-03-19, 06:40 PM
Stroock639
Stroock639's Avatar
not that it really helps, but if you only have $500 to spend you shouldn't have bought a car with such expensive parts lol
Old 06-03-19, 06:45 PM
bradland
bradland's Avatar
Were the rotors ever resurfaced or replaced?
Old 06-03-19, 06:59 PM
Kansas
Kansas's Avatar
Worn strut rod bushing may be causing most of the problem. I had new OEM strut rods and bushings installed on the 2000 LS400 Platinum I drove for around 11 years and all the horrible vibrations completely vanished. The bushings are usually worn and causing vibration and lack of stability in high winds by 75,000 miles more or less. When I had my 2000, it didn't seem that many mechanics understood this issue.
Old 06-03-19, 07:39 PM
kambam3627
kambam3627's Avatar
Lol, i mean as in terms of what I want to spend at the moment, 500 won’t obviously cover it all but eventually
Old 06-04-19, 04:35 AM
billydpowe
billydpowe's Avatar
I vote with Jim (Kansas) on the strut rod bushings, I bought a pair from bradland a couple of months ago and had them installed (and mine were not even beat to death) and it made my LS drive like a new one... amazing..
Old 06-26-19, 07:52 PM
kambam3627
kambam3627's Avatar
Default Update
I had previously posted on a shake I had when breaking.... new rotors and tires fixed the problem or so I thought..... it’s back, and worse. Only happens when breaking and the steering wheel and front driver side shake. Ball joints and control arms look good. Shocks have been blown for awhile so Ik its nothing new on that part, but the tie rod is very loose, could that cause the front end to shake very bad???
Old 06-26-19, 08:09 PM
Bylan
Bylan's Avatar
Yeah tie rod will do that, the wheel is literally steering left and right when you're braking if it has play in it. Don't drive with bad tie rods, they get loose they fail and you crash
Old 06-26-19, 08:17 PM
kambam3627
kambam3627's Avatar
Well I’m SOL, I’m going on a little trip 300 miles tomorrow.... then 300 back.... the car has gone 7K like this... praying 600 more
Old 06-26-19, 08:21 PM
Fit1too
Fit1too's Avatar
If the driver's side fails it could pull you into oncoming traffic. Have someone look at it right away!
Old 06-26-19, 08:28 PM
Sin1UZFE
Sin1UZFE's Avatar
I only had 500 to spend when I got it as well. I did it in batches.
Old 06-26-19, 09:13 PM
kambam3627
kambam3627's Avatar
It is drivers side, unfortunately I must do this trip tomorrow. I’m praying it’ll be okay, gonna drive 50 at most.....
Old 06-26-19, 09:14 PM
Sin1UZFE
Sin1UZFE's Avatar
Good luck, u should be fine
Quick Reply: Suggested suspension parts replacement
