Low washer fluid message
The low washer fluid message appeared not long after I purchased my 98 model. I tapped on the top of the bottle as suggested in the forum and the message disappeared. Over the winter the message returned, and the tapping did not solve the problem. I decided to disconnect the sensor until warm weather returned. I attempted to repair the original sensor, but it had a split along the rod that the float operates along, so I purchased an OEM replacement unit and found time to install it over this past weekend. I just did not want to leave stuff unplugged on my car—before you know it, the whole car is unplugged! It is simple, but as always, I learned a thing or two and wanted to share the results.
The part# is – 85397-50090, eBay, $65, free shipping.
Note: The third picture shows that the original rubber seal/gasket remained in the washer bottle when I removed the old sensor. This happened because I was afraid it would leak and used clear RTV sealant on it when reinstalling after my initial failed repair attempt. I removed it separately. Also, the new sensor and seal/gasket have to be installed together as a unit which is the tricky part!
- First, raise driver’s front side (makes it easier to put a pan under the work area, etc.)
- Remove the 4 bolts (red arrows) and 1 plastic push pin (blue arrow) holding the fender liner to the underside of the car
- Pull fender liner down enough to access washer fluid bottle and sensor
- Tuck something up behind and below the washer bottle to allow fluid to flow out, down, and into a catch pan once the sensor is removed (I put a piece of cardboard in a plastic protector sleeve and used that)
- Position pan to catch washer fluid
- Pull the sensor downward to release from washer fluid bottle (there is only a rubber seal/gasket holding it in place)
- Allow fluid to drain completely
- Install new sensor
The following 2 users liked this post by Fit1too:
spuds (06-09-19),
Stroock639 (06-10-19)
