40k service due any suggestion on what to have checked out?
Hey All
Well I will schedule my LS to go in for its 40k service next week at JM Lexus. I'm just wondering if there are any things in particular I should asked to be checked or done? I did have an issue with a windshield washer jet being blocked but it fixed itself. I also posted once that my Fuel Gage didn't go all they way up when I filled the tank but that fixed itself (it might have been a one or two time problem cant remember).
So the only little issue I have is that maybe once a week when the drivers window is going up it sometime goes back down after only going up halfway. It must be the pinch sensor is off calibration. I open and close the driver window at least 4 times during a work day due to security gates at the Daycare and work. So maybe once or twice a week the windows goes back down when it should not. Do you all know if this is something that can be adjusted with out the door being taken apart? I do not want any rattles because the door was not put back together properly or because the factory seal for some part was messed up. The problem does not bother me that much at all so is it worth it??
The only other things I was going to have changed are 2 C-Best options
Trunk Lid opener with just 1 press of the trunk button on the remote vs. a .8 second press/hold then open
Auto Lock Delay to 60sec vs. 30sec after unlocking the doors with the remote and not opening a door
My car runs so perfectly I cant think of any thing else to do. I guess this is a good thing.
Thanks
Jerry
Thanks
Jerry
Hello out there...... anybody?
Hey one more thing and maybe you all have experienced this. When I start my car the engine turns several times before actually starting. My other NON Lexus cars use to start right up with out delay. Is this normal? Can something be adjusted to speed this up.
I have gotten use to this but if my wife or my buddies want to start the car they always have to try several times cause they don't hold the key long enough. They always think something's wrong, kind of annoying...
Thanks
Jerry
Thanks
Jerry
BrownPride
02-12-23 09:31 AM
fibromd
ES - 6th Gen (2013-2018)
06-03-14 01:57 PM
