Control arm 1991
I’m looking to replace left rear lower rearward control arm and bolts on my 1991 LS400. I can’t seem to find the correct one anywhere. The part is discontinued and not available at many dealers. Any suggestions? Thanks
The bushing, however, is available. Is the arm physically damaged or would a new bushing suffice?
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/900x658/inked1991r_li_55542ca4f206d50b5f761465c81b0a6d54df2fe5.jpg)
I just typed "1990 ls400 rear control arm" in E-bay search field and got few hits. Would that work? (probably aftermarket though)
Or you could get it from a donor vehicle and then change the bushing. Should be as good as new then.
KMinAF
05-15-09 08:21 PM
