Hood liner clips
Am looking for the 30 mm diameter clip depicted in the posted image with the square "pinetree" which does not appear to be a Toyota P.N.
Try calling a local auto part store. They usually have a cross reference search engine on their computers. They can search OE and aftermarket part numbers.
I searched for about 30 minutes for the part number you show in your pictures. Absolutely nothing comes up. Closest I was able to find was a GM fastener that was 30mm but had a 17mm stem.
Anyone know a source for this clip
OEM plastic 25 mm plastic clips do not hold the hood liner taught to the hood as do the 30 mm aftermarket clips with the ""square tree".
Am attempting to identify the aftermarket clips.
Thanks.
Aftermarket clip on left with square "tree".
Thanks.
What are the exact dimensions? I found one with 30.5mm head, 11mm length, 6.6 x 6.6 mm square stem/tree.
EDIT: just found a whole bunch more, similar dimensions, but not same - from 11- 16mm long, between 5 and 7mm wide, all square stem.
Seems that you will have a better luck just looking up Subaru, GM, Ford, Honda and other "hood liner retainers".
