Help, I can't find "rear bushings"
I want to replace two rear bushings per side on my Lexus and I cannot find the parts, here is a picture of what I need:
I was looking for the same thing a few months ago. I didn't change mine cuz of too much rot. (afraid the car would fall apart ) It's the ADUS 583. I know I saw them but can't find them now. The only thing I see now is these poly bushings;
https://www.armstrongdistributors.co...g-kit-x2-89-00
Go with your own judgement, and research, because I noticed under their part #583 it has the OE#4871050020 which is actually the other lateral arm. ( Nothing to do with bushings )
OMAHA (08-27-19)
is your part here at Amayama?
https://lexus-europe.epc-data.com/ls.../chassis/4804/
Click part number in the scheme or in the list:
9411041000 ** Std Part
48530 ABSORBER ASSY, SHOCK, REAR RH
48553D CAP, REAR SHOCK ABSORBER, RH
48540 ABSORBER ASSY, SHOCK, REAR LH
48554A CAP, REAR SHOCK ABSORBER, LH
9413061000 ** Std Part
48750G NUT (FOR REAR SUSPENSION SUPPORT)
48724 DAMPER, LWR CONTROL ARM DYNAMIC
48750A NUT (FOR REAR SUPPORT TO REAR SHOCK ABSORBER)
48755 SUPPORT, REAR SUSPENSION
48257B INSULATOR, REAR COIL SPRING, UPPER
9017908184 ** Std Part
48341 BUMPER, REAR SPRING
48812 BAR, STABILIZER, REAR
48815R BUSH, STABILIZER (FOR REAR)
48080 CYLINDER ASSY, PNEUMATIC REAR RH W/SHOCK ABSORBER
48090 CYLINDER ASSY, PNEUMATIC REAR LH W/SHOCK ABSORBER
48830A NUT (FOR REAR STABILIZER LINK)
48824R BRACKET, STABILIZER (FOR REAR)
48231A SPRING, COIL, REAR RH
48231B SPRING, COIL, REAR LH
42304A BOLT (FOR REAR AXLE CARRIER)
9011908661 ** Std Part
42304B NUT (FOR REAR AXLE CARRIER)
48830 LINK ASSY, REAR STABILIZER
9011914040 ** Std Part
9020114020 ** Std Part
48190R CAM ASSY, CAMBER ADJUST
9017014012 ** Std Part
48198R CAM, REAR SUSPENSION CAMBER ADJUST, NO.2
48730A ARM ASSY, REAR SUSPENSION, NO.2
9017912138 ** Std Part
9011912284 ** Std Part
48770A ARM ASSY, UPPER CONTROL, REAR RH
9017912137 ** Std Part
48790 ARM ASSY, UPPER CONTROL, REAR LH
9011914035 ** Std Part
9017914015 ** Std Part
48703C NUT (FOR REAR SUSPENSION ARM)
9010512277 ** Std Part
48780A ROD ASSY, STRUT, REAR
42304 CARRIER SUB-ASSY, REAR AXLE, RH
42305 CARRIER SUB-ASSY, REAR AXLE, LH
48710A ARM ASSY, REAR SUSPENSION, NO.1 RH
48720A ARM ASSY, REAR SUSPENSION, NO.1 LH
9020112071 ** Std Part
9017012038 ** Std Part
9017914045 ** Std Part
OMAHA (08-27-19)
Is this the part?Its in the rear suspension bits at Amayama
TAB710
Weight 0.10 kgs
https://www.amayama.com/en/part/febest/tab710
FromPrice, USD
Shipping cost toUnited States of America
Delivered to you by ?
AvailabilityUAE
2.70 ea,15.53 shipping
SILENTBLOCK
FEBEST (TAB710)
TAB710
Weight 0.10 kgs
FromPrice, USD
AvailabilityUAE
OMAHA (09-20-19)
I found this place; http://www.foreignautosalvage.com/af...-bushings.html They have the ADUS 583 listed but you would have to call them to find out if they actually do have them.
Good luck.
Good luck.
OMAHA (10-01-19)
WhiteLS4OO (09-12-19)
Rocar has them. They are OEM formula rubber.
http://www.rocar-usa.com/category.ph...Year=1995-2000
Hmm I wonder how their motor mounts compare to OEM
OMAHA (09-20-19)
94 ?
Made in________ ?
jdm93400
09-05-18 07:40 AM
anthonyini
07-21-17 07:53 AM
