1997 LS400 Drivers Side Low Beam
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/400x169/20190827_145331_f48081a86c054d1d0b20be8cb028fac969b86d2d.jpg)
Hi, I lost my drivers side low beam last week after having had a few minor problems in the past. About a year ago, my low beam seemed to stop working. After simply removing and reinstalling the same bulb, it came back on. I guess I just touched it and it worked and kept working for about a year. I assumed it was the connector.
It went out again last week. I replaced the bulb and the connector. Still no light. I checked the fuse box and no blown fuses. Power was properly moving through the proper 10amp fuses when the lights were on. However, I am not getting power to the bulb wires. I replaced the headlamp relay with the relay from my '98 lexus and the left headlamp still didnt come on.
Am I missing something? Why is the passenger side working but the drivers side not working? Are there separate ballasts or something or is it possible that the wire somehow has a connection flaw? I am assuming that the wire goes straight from the fusebox to the connector to the headlight.
Brian
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1018x1810/1997lexus_leftheadlightnotworking_803688c71a71e2b33937a0bfe3787970ea00fa72.jpg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1250/lexus400031_37d9298096720ea23ca1dcd7b467bbc7171fc1d3_f70a4d89853bd5e4e551a0f4ef0101a670d13a23.jpg)
Replace Low Beam HeadLight Bulb on LEXUS LS400 1997 ~ From the back of enclosure how do I identify which bulb is the Low Beam Bulb?
The 3 prong bulb in the upper and outer area of the headlight fixture has the low beam built into it. If the bulb has 2 prongs then it is a secondary high beam bulb.
