1990 LS - Wont turn over and no fuel
Car has been sitting for awhile waiting to have the transmission replaced, but engine was running prior to sitting. I will go through the diagnostic steps to test the electrical components/relays, but was hoping that the symptoms of the car not cranking and the fuel pump not priming that it could point to something specific?
Battery is good, borrowed from a running LS. All fuses are good (under dash/engine bay). Engine main relay is clicking over.
When I turn the key to "ON" I don't hear the fuel pump priming (fuel pump relay is not clicking over). When I turn the Key to "START" nothing happens as well.
The searches I've done people experience either one of the symptoms or the other, not both. I plan on checking the following if no one has any feedback:
-ECM
-Circuit opening relay
-Ignition Relay
-Fuel pump relay
-Fuel pump resistor
Use some of the diag. steps in this thread: https://www.clublexus.com/forums/ls-...questions.html
Any ideas?
-ECM
-Ignition Relay
-Fuel pump relay
-Fuel pump resistor
Any ideas?
-NSS (Neutral Safety Switch),
I will add to your list.
gpshogan
10-18-12 09:32 AM
