Troubleshooting P 1354, P 1351, P0420, engine codes
I am troubleshooting my 2000 Lexus LS400. I have 176,000 miles on this vehicle and the other day I had an engine light come on and the VSC off light come on with the engine light. When these lights came on the engine started idling and running rough. When I had the engine codes checked I had a P 1354 , P 1351 , P0420, and a P0300. When I research the 1354 it points to the VVT solenoid and they suggest getting oil changed in which I did and had the codes cleared. But yet the same two lights and codes keep returning. Hoping someone out there has experienced the same issues and could give me some suggestions on where to start. Someone had stated that the 300 code or misfire could have been caused by the 1354 code. Thank you for any suggestions and help it is much appreciated.
The video below is about an LS430 but it may help you because of the similarity most.
mbrown1782
02-26-13 07:53 PM
ph0ngster
12-14-05 08:08 AM
