Need help? Replaced struts to Tokico and not happy
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I am desperate for some guidance. I recently replaced all 4 struts on my 94 LS to Tokico. I went with Tokico after several opinions from many of you in the chat room. I was thinking the ride would be close to the original with just a slight more stiffness. Well, these are really bumpy and stiff. I also have a loud noise (as if something is bottoming out from both front strut areas) when going over a bump. I have had the suspension checked out and there appears to be nothing wrong with the system.
I replaced them with part #'s HU3704/3705. My car was mfg in 8/03 according to the sticker inside.
So, could the struts be bad? Should I have gone with the OEM for the smoothest and best of rides?
Any help and guidance/suggestions would be greatly appreciated.
Thanks
William
Thanks
William
actually, KYB are the closest replacements to OEM if not better... Tokico Blues are for handling and performance.. I use KYB and it rides smooth even with 18in wheels
well of course they are good.. its what comes with the car.. however, for a car thats 10 years old.. it doesnt make sense to pay 100 - 200 per strut from the dealer, when u can pay 60-70 per strut aftermarket
Struts for 1st generation LS400 cost Can $75 each (about US $55) at my local Lexus dealer. Why bother with aftermarket unless you want to improve the handling.
Anyway, any idea about how long the stock struts last ? My car has 150K miles and the suspension is still OK.
tvd51
tvd51
Thanks for the help and guidance. No doubt, after riding in a friends' car with OEM replacements for struts, the ride is much like the original.
Definitely the way to go.
fyi, I just replaced mine finally at 150,000 miles. Unbelievable.
At 150K+ my OEM struts ride smoother than many newer cars, and at <$50 a pop they are a steal when compared to the aftermarkets. They outlasted the spring isolator towers. Now that's reliable!
Rice,
Did you replace the coil springs as well ? They cost twice as much as the struts. I wonder if I should replace just the struts and keep the old coil springs ?
tvd51
tvd51
First of all you are comparing new struts to 10 year old struts.........The new struts will soften up ....But the noise could be the spring is not seated right on the rubber mount........or you have some other worn out parts.
Originally posted by tvd51
Rice,
tvd51
Rice,
tvd51
