Help!!!Water and oil leaking
Is it normal for oil and water to leak when water pump seals go bad.It has a rattle now when engine is on.
Thanks for any info
Thanks for any info
Originally posted by mbws400
130000, the rattle is in the water pump. not in the engine
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Mike
Originally posted by mtsao
Please correct me if I'm wrong, but isn't the water pump <<inside>> the engine?? Hence when engine is 'open' and timing belt is being replaced, water pump is replaced also??![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Mike
Mike
mbws400, when the water pump leaks its only leaks water, but there's the front crank seal and cam seals that can leak oil. I recommend to replace all the oil seal when do the water pump+ check all the pulley and tension behind the timing covers.
GibbsLexus
08-09-17 07:18 AM
andyman32
03-17-13 07:58 AM
