94 LS400 electrical gremlins
94 ls400. I am having intermittent power issues. My blower fan, brake lights, and instrument panel dimmers all cut out intermittently. I also lose cruise functionality, but i still have the cruise icon on the panel. I am also having to use the park lock override button in order to get out of park. I have checked all fuses and breakers, both physically and with a test light. It looks like i am getting intermittent power to the green 40a rr defog breaker as well. Cant find anything else out of place. CEL, TRAC light, TRACOFF light, and abs light are all on. Are there any relays that would have all of these systems in common? Is there a point where a single power source connects all these systems? Tried replacing stoplight switch already. No change. I pulled the codes but didnt get anything helpful. Any suggestions appreciated.
The left side of the trunk lid is a wiring harness. Check that for any broken wires and repair as necessary.
This one as well:
http://www.lexls.com/tutorials/lighting/bulbout.html
This one as well:
This one as well:
This one as well:
Thats been dealt with
Also, all of the electric motors for my heat settings still function, and my heater core is producing heat.
Also forgot to mention that i have no power under the dash at the following fuses: STOP 25A, FOG 15A, ECU-B 15A, MIR-HTR 10A, PANEL 7.5A, AND TAIL 15A
Ecu has been dealt with. Was able to call the company who did the work and confirm too. The technician also said that, in his opinion, the problems im facing are unrelated to the ecu.
I've had test lights light up with minimal voltage that sent me on wild goose chases. Granted, they were newer German cars and different systems. Do you have a way to check actual voltage through the fuses?
Does it happen during different driving conditions or is it 100% intermittent? No matter day or night, rain or dry?
"Also forgot to mention that i have no power under the dash at the following fuses: STOP 25A, FOG 15A, ECU-B 15A, MIR-HTR 10A, PANEL 7.5A, AND TAIL 15A"
What have you tried to do to rectify this issue? Have you swapped in new fuses? Have you looked at the wires leading into the block to see if they're burnt?
It's possible you have a short, it's also possible you had a surge of voltage and popped fuses. What is your voltage gauge saying while the car is running?
Do your brake lights actually work?
It would be the best if I were able to show you the FL box and the terminals for your quick action but sorry that I don't have any photos nor drawings of a 94.
BNastee (03-17-20)
I'd simply check the terminal 1B of the FL box lifting it because all those loads STOP 25A, FOG 15A, ECU-B 15A, MIR-HTR 10A, PANEL 7.5A, AND TAIL 15A are coming from it.
It would be the best if I were able to show you the FL box and the terminals for your quick action but sorry that I dont have any photos not drawings of a 94.
https://www.clublexus.com/forums/sc-...ml#post9169897
If the terminal 1B of the FL box is OK, the next step would be to check the other side of the white cable which is connected to the junction box under the dash ( behind fuse panel where those fuses STOP 25A, FOG 15A, ECU-B 15A, MIR-HTR 10A, PANEL 7.5A, AND TAIL 15A are there ).
BNastee (03-17-20)
This post might help you some although it's about a SC400. Especially the 2nd photo shows the terminals.
Yamae (03-16-20)
I'm glad that you quickly fixed the problem and the quick report of the result.
WhiteUCF (03-16-20)
