2004 LS430 Info on site
Lexus has started a sign-up service to get information on the all new 2004. If you click the signup button u enter all ur info and click submit. then u should recieve info for the 2004 LS430. ***If you look to the left of the forum, im pretty sure you can see the 2004 LS430 in a front view photgraph
Mink92890
Mink92890
I'm getting a server-side error message.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Can you post the info/pic you get from the page inside if you still have access to it?
Edit: Ah!! The pic at the info submission page should be it already! Didn't notice (the change is indeed subtle).![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
(cScriptItems.GetCurrentResponseInventoryItems) (cTransNon.GetCurrentResponseInventoryItems) ADODB.Field error '800a0bcd'
Either BOF or EOF is True, or the current record has been deleted. Requested operation requires a current record.
/testing/lslnch/script.asp, line 66
![](http://usalexus.programhq.com/testing/lslnch/images/hndrsr_main_pic.jpg)
