Oil smoke around pass. exhaust manifold area
1999. Very strong oil smoke at start up around passenger side exhaust manifold area. Anyone know what this could be? The smoke continues at normal operation but not as bad as at start up.
thanks
Rick
thanks
Rick
If it's not leaking at the cam cover than it's probably a leak in the power steering system.
Rep115i (04-02-20)
yea probably a leaking valve cover, it's worse at first since the oil is constantly dripping a bit from it so there's more to burn off at first as it drips onto the exhaust
you should see that it's wet with oil around the valve cover, could simply be a matter of having to re-torque the bolts
vintagelex
04-28-13 03:53 PM
