Crank but won't start
Hello Lexus Community,
I need help on my 1996 LS400. Its about 127K miles. It has no prior issues, everything was running good until when I replaced timing belt, water pump, and pull out crank pulley. It all started when I replaced the starter and later decided to replaced other stuffs as I mention above in a hope to keep the car well maintained. After replacing the starter the car start right and seem no issues but only after replacing the timing belt, water pump. I checked all cam and crank sensors which I never took it out or replaced and looks they all are in original setting. The timing belt also look aligned with the timing but could not think of another issues. Needs help please.
Oh yea, only once. On my first T-belt on my 93 I was about half way together, looked down, and said "what the hell is this thing and where does it go?" Luckily I saw it when I did.
Didn't remove it? That's a first, it needs to come off to get the T-belt off. 🤔😀 I would check the crank sensor (with a meter) to see if it's in spec. Does the RPM gauge move when you crank the engine?
bradland (04-27-20)
I taught I replied you earlier but I do not see the post. If this is duplicate please ignore it. Yes you are right the crank plate needs to come out first. Now I remember taking it off and putting it back after installing the belt. The RPM does not move when crank. I wonder how that may went bad so quickly as it was no problem before installing the timing belt. Also Can you please help what crank pulley installer you use, I tried two different one with adapters but does not fit it right. I do not know the exact size of the crank bolt.
I was little bit confused how should be the crank pulley be installed. At first I did align it with key and used impact gun as I do not have high torque wrench. But after watching couple videos I thought the crank pulley should only be installed manually using an installer tools. I am not sure the installation of this pulley is different from others. To me it was easy one when using the impact wrench. After the videos I was trying to find right installer so I that can install manually. But still did not find it. Now I am more confused when you said I do not need an installer to installer the crank pulley where as youtubers says otherwise.
Battery in key? I know sounds dumb but seen it happen in Toyotas.
I have not got time to check the spec of the sensor yet. I have to do a research for it, not sure what's the proper way to do that. I will tear it a part again and check every wiring and sensor. Will give last shot or going to junkyard.
Tofubento
Performance & Maintenance
12-19-11 10:38 AM
95SC400
12-28-04 09:16 AM
