Thermal barrier between upper and lower intake manifold plenums
Toyota used two piece intake manifolds with steel gasket sandwiched between.
However, said gasket conducts heat from the lower intake manifold section to the upper half.
Applied a thermal barrier to bottom of intake manifold resulting in temperature reduction to top of manifold...
After sprited running, can now more comfortably place my hand on top of intake without burning fingers.
In an effort to reduce heat transmission further, am now focusing attention on thermal isolation between upper and lower intake sections
Investigation of materials suggests Teflon offers extremely low heat conduction, is suitable in temperature extremes, impervious to most chemicals, will not react with Aluminum and is quite durable.
