Muffler Delete Mod
Old 10-16-03, 12:58 AM
{-.-}'s Avatar
Originally posted by RA40
Which would you think creates the most pressure...the silencers or mufflers? If you were to remove one set, which would you suggest
For me it would not matter........ The center muffler & catyolic converter also help with the back pressure.
Right now Im trying to get pipes made so I can remove my catyolic converters.
Lord of the Celsiors is running straight pipe...... his is still running good if it wasnt he would of put something back to help with the back pressure.
Old 10-16-03, 08:29 AM
JBrady
JBrady's Avatar
As far as the muffler delete goes, looking at the pics on Lextreme, the silencers have all that heat discoloration. Which would you think creates the most pressure...the silencers or mufflers? If you were to remove one set, which would you suggest
Mike, the silencers are the biggest choke on the LS400s hence the discoloration. If you remember there were 2 distinct areas of discoloration, one at the Y section that split the exhaust back into duals and the other in the silencer case itself. A single decent Y section feeding either dual pipes or dual straight through resonators would be a good choice. Of course that still leaves the bottle neck of the first Y section and 50mm center resonator.
I am actually leaning towards dual pipe set up, after my custom cat back parts, plumbed into my existing rear mufflers. Those mufflers are so easy to remove I can do it at the strip for back to back testing. Also, I intend to place pressure probes at various points in the system. Since I will be replacing EVERYTHING from the cats back (except for the rear mufflers for now) I will have a chance to do a variety of tests... I like having good reliable test information.
NOW... PLEASE... ONE MORE TIME... to other peoples posts in this thread... engines do NOT need or want backpressure. This is an incorrect assumption made by people with partial information. It has been said so many times that many people just assume it to be correct. The PROBLEM is that large pipes LOWER velocity. It is the loss of velocity that hurts low RPM power. The solution is to build the best flowing lowest restriction system from the smallest diameter pipes cabable of supporting the high RPM power output of the engine. This is why I recommend 2.25" pipes and not 2.50" pipes. So please, everyone, stop saying an engine needs exhaust backpressure.
Old 10-17-03, 03:58 PM
RA40
Super Moderator
RA40's Avatar
Thanks John-
One of these days I'll run it by the exhaust shop and see what it is gonna take. I'd love stainless piping but I suspect it will be $$ if it is readily available in the 2.25" size.
Old 07-08-05, 05:27 PM
lspower
lspower's Avatar
Originally Posted by Lexkost
Just remember you need so much back-pressure in the system ...........So be carefull !
granted this is an old thread but i wouldnt want people to read this and believe it because it is far from true, NO car needs backpressure, every car need good scavinging for power...!!
example sc300.... inline 6, n/a, 2.5in from the header (ex: xerd header) w/o cats back would be perfect
same only with 3in not good loose power
Old 07-10-05, 08:08 AM
morgsss
morgsss's Avatar
Default heres mine
here is mine they make it go fast
Old 07-10-05, 07:30 PM
gtfour43
gtfour43's Avatar
I hope your not turbo cause with all that pressure coming out of your exhaust you might pull wheelies and thats very dangerous
Old 07-13-05, 08:33 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i just did this mod (thnx to lextreme's guide) and it sounds MUCH better. only thing is, to anyone who has heard an LS w/o rear mufflers, IS IT TOO THROATY??
i ask this because i am 16 y.o. and driving my own lexus. the last thing i want is to have cops all over me.
also, just to make 10000000 percent sure, this mod IS legal in SoCal? RIGHT??!?!
sry, just some random confusion.
thnx in advance
-Annant
Old 07-13-05, 08:44 PM
Pagong
Pagong's Avatar
The sound is very throaty and mellow at the same time.
It doesnt overpower the cabin at all.
I bought LSpinoy's mufflers and they sound great.
Old 07-13-05, 09:51 PM
PureDrifter
BahHumBug
http://www.leginfo.ca.gov/cgi-bin/wa...ction=retrieve
this states that a car has to have a muffler.
now, since the car still has the silencers and center mufflers on it, do those get counted as mufflers?????????
if they dont, im putting the stockers on this weekend and looking for a cheap used exhaust.
-Annant
Danbin1991
07-01-19 03:29 PM
swaangin
02-22-18 03:09 PM
LexusWhy
07-16-17 08:37 PM
jdmboyee
04-14-16 08:30 AM
Nguyenrrr
02-09-13 05:54 AM
Quick Reply: Muffler Delete Mod
