2004 - 2006 ls430 differential in 1998 - 2000 ls400
The rear differential gear ratio on the 1998 -2000 LS400 and 2001 - 2003 LS430 is 3.27 : 1.
Both use Aisin A650-E 5-speed transmission with .753 fifth gear.(but different torque converter P.N.s that no one can answer as to whether differences)
The rear differential gear ratio on the 2003 - 2006 is 3.769 : 1 and uses A761-E 6-speed transmission with .586 6th gear
See:
https://en.m.wikipedia.org/wiki/Toyota_A_transmission
Now the question;
While the differential appears to be a bolt in proposition, does anyone know whether swapping the necessary transmission and speed sensors is plug-and-play practical?
Correct speedometer, Engine, braking and traction control functions important.
Thanks
See:
Now the question;
Thanks
See:
Now the question;
Thanks
See:
Now the question;
Thanks
You may want to try it and see what happens since it won't harm anything mechanically, you may be able to adjust for tire size and if you can this becomes insanely easy since you can just fool the computer into thinking you have really small tires instead of a totally different ratio. That way it will display correct speed, and al other functions since according to it the tires simply changed size, that method is used on dodge vehicles when we swap them to 4.56 and up gears
YODAONE
11-14-19 11:13 AM
qewani1
03-08-15 12:07 AM
