Temps
Temps
How high above the 2nd to the last line on temp gauge is normal? It's 106 here and I drove about 120 miles today and when in town in drive through it went a few ticks above. Basically to middle of gauge. Hasn't gone that high til temps hit these highs
Cleaned out the front of ac and radiator fins months ago
Edit: topped out at 109. According to car.
If it's anything other than this, it's hotter than normal.
I believe this gauge has some "play" built in, where it will read the same level +\- 10 degrees or whatever it is. If you're a tick above it, the coolant is quite a bit warmer than the thermostat wants it to be.
Could be thermostat, could be temp sensor, could be fan clutch.
Some testing ideas to diagnose here:
https://www.clublexus.com/forums/ls-...an-clutch.html
The bracket mount was replaced? Or the actual fan clutch was replaced? One is a mounting plate, one is a thermal coil that measures the heat of the radiator and adjusts the fan speed.
As for sensors I found two
https://www.lexuspartsnow.com/parts/...422-30030.html
https://www.lexuspartsnow.com/parts/...()&Location=pd
Both?
I'm actually not sure which one may be causing the issue. Do the normal testing methods to make sure your fan clutch is working as it should, then move on to the temp sensors.
Here is some more info on them:
there are two coolant temp sensors, one for the gauge and one for the ECU. make sure you replace the right one, if replacing!
the one for the ECU is the one that affects your MPGs.
https://www.clublexus.com/forums/ls-...ange-pics.html
https://www.clublexus.com/forums/ls-...read-this.html
and the temp gauge should not be right in the middle. my car's needle always rested below middle at operating temp (just like the picture above).
$110 and $60, not cheap parts.
There may be ways to determine which may be causing your issues, but we're at the end of my knowledge here on the subject. Hopefully someone else weighs in who knows more to help point you in the right direction of which may be best to start with.
Do double check your fan clutch though - you are indeed overheating on very hot days. Failing temp sensors give weird results even on cool days based on my ramblings through those threads. The car should be able to handle 106 degrees. I had to replace my fan clutch twice - The original failed, the replacement was FUBAR and had to be warrantied. Just FYI.
Tho my situation may not be like everyone elses and shouldnt be referenced. Troubleshooting is key but in my case its quicker and cheaper given everything else has been changed out
Just my opinion and experience; the temp sensor for the ECU I bought one for my 93 from Autozone in 2011 for $20, took it from the 93 when I junked the car and put in my 94 in 2016 and it's still working fine. I feel aftermarket is fine for that sensor, some will disagree.
Sin1UZFE (06-10-20)
My 99' LS for the very first time, also went exactly to the middle of the gauge where it normally would otherwise be just above the 2nd mark. I use to live in MI but moved back to AZ 2 weeks ago. But i was climbing a 6000 ft hill and it was 105+ outside with about 3 panes of glass from an entertainment center in the back trunk and some other misc stuff in my trunk. Slow going up the hill since I was following my friend driving the Penske truck and trailer, so I was going about 45 mph. I had the AC off thinking it would be less taxing on the engine and the temp got elevated to the middle, but once I turned the AC on, it immediately dropped even though we were still climbing. So i guess the AC electric fan helped bring the temps down.
Sin1UZFE (06-11-20)
The thermostat starts opening at 180 and "SHOULD BE" fully open at 200 or 205. This doesn't necessarily mean your coolant temp will stay at 205ish, it can and will go up from there.
220 is still considered normal but anything higher than than may be cause for concern. Other factors obviously come into play here, highway driving vs stop and go etc...
The coolant cools everything it comes in contact with but if there's not enough air moving through the radiator the function of the fluid is limited.
