Siphon transmission fluid via dipstick
Has anyone changed out their transmission fluid (partial change) by siphoning out through the dip stick?
How many quarts of transmission fluid should I expect to remove using this method?
Thanks
Thanks
I Haven't tried this method. The tube in the LS is a fairly small diameter so check that the siphon hose will fit. If it does you'll easily be able to measure what comes out is replaced. Would be nice to not have to get on the floor by doing this.
I use the West Marine Oil Extractor.
Has necessary tubes and very durable
Plan on 3 to 5 quarts.
The extractor container measures quantity so you know how much to replenish
I also use for oil changes
Works well but is slower obviously, I prefer dropping the pan to inspect and replace the filter and clean off all residue. If you are not interested in replacing the filter then it's a great way to do it difficulty wise and the tool is very useful for fluid service
No you should only do it from the bottom pan......
Oh unless you have a tool for it I mean I guess that is better if Yoda says it is. I thought you were planning on using a turkey baster and tubing or summit.....
Op inquired about siphoning oil via dipstick
The A341D, A340E , A650-E did not use filters in the tradition sense, but do use fine screens.
First, I have used transmission drain, oil extractor (works well) and removed transmission pan to refresh FIPG...and check screen (zero sediments in screen)
Toyota did not use transmission pan gaskets, but high quality FIPG (form in place gasket)
Removing the transmission pan requires removing transmission pan bolts, slicing through FIPG between the pan and transmission housing.
If you have the correct special service tool, it is easy, otherwise tight quarters to work another tool.
Mating surfaces must be free of all FIPG and oils, otherwise the new FIPG does not adhere well...and transmission oil continues to drip from housing onto FIPG mating surface.
If no leaking or unusual shifting, then it appears you posted for advice on using an oil extractor for drain and fill of transmission because you are attempting to avoid the following:
crawling under the car, removing the drain bolt, using a drain pan, removing the transmission pan, scraping off FIPG, purchasing and applying FIPG.
Correct ?
Correct ?
That West Marine 6.9QT pump is $69 here:
https://www.westmarine.com/buy/west-...uart--11047123
The 2.9 QT pump $54:
https://www.westmarine.com/buy/west-...14?recordNum=3
Thanks Yoda! I want to change the lawnmower oil easier than tipping the thing on its side.
Correct ?
Correct ?
For FIPG prep the 3M Rolox bristle disks work excellent and are purpose designed for extremely rapid yet completely safe cleaning of aluminum surfaces. Makes it crazy easy but if you don't have those tools then it would be much worse.....I don't know how it is to do on the ground since I've always done it in the air.
While a great idea I think it's easier just to buy a set of ramps and drain it from the bolt. A lot more effort goes into pumping the fluid out then just turning the bolt and letting it drain. All the work that you do on your car Yoda and your saying replacing the crush washer is too much extra work.
I have a fluid extractor/dispenser as well and absolutely love it. It's one of those tools you don't appreciate the full value of until you own one!
To the OP's question- yes you can remove fluid via the dipstick but the trans cooler lines are more efficient. Removing through the dipstick you are limited to the amount of fluid in the pan.
Many forum members have great results diverting the flow of fluid out of the trans cooler into an empty container. Mark the container in Qt increments. Start the car and let the fluid flow up to the 1 Qt mark then shut the engine off and add 1 Qt of new T-IV through the dipstick tube. You can do this in 1 Qt increments, totaling 3 or 4 Qts replaced, then repeat in a month or so if necessary. Some people just keep going all the way until the fluid dumping into the container is bright red. Your choice but obviously have the required amount of fluid on hand.
i second bradland's method but be aware to replace the same amount of fluid that comes out!
using that method, you will drain more than what's in the trans pan which typically is only 2 quarts (1.9 liters).
there is over 8.7 quarts (8.3 liters) in the entire system (torque converter, valve body, etc).
and remember to only use toyota type-IV ATF!
and it's the driver's side according to this link:
http://www.lexls.com/tutorials/trans...ransflush.html
bradland (06-11-20)
