JDM 1UZFE VVTI swap into a USA LS400?
I have a 2000 LS400. After my botched timing belt job, I'd rather just get a whole new engine in. I see some legit ones on Ebay that are JDM-imported here to SoCal.
My biggest concern is what I'd need to swap over from my USA 1UZFE VVTi (that was running perfect before I screwed it up) into the JDM engine -- if anything at all.
Also, I'd need it to pass smog. The sellers I've contacted said that the engine can be placed in and, without putting on USA emission components, will pass smog. But I'm kinda iffy on that.
I read a very similar thread here: https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/799461-jdm-vs-usdm-1uzfe-vvti-questions.html but I'm trying to gather up as much info as possible.
I read a very similar thread here: https://www.clublexus.com/forums/ls-...questions.html but I'm trying to gather up as much info as possible.
To use many of these JDM parts below would not be practical. In case you use the JDM ECU, the quickest way would be to use original USDM fan and the fan clutch as well as to use electric fans modifying the signal which control the hydraulic pressure control valve.
Other than the fan, there is a minor difference at the purge system. The exhaust gas control would not be a big problem as long as the JDM engine is not too old since our regulation here is as strict as the Californian's except the gasoline vapour. That's why the purge system is more complicated in your state.
e30antonio (06-19-20)
The biggest issue would be the cooling fan. A Celsior's engine uses a totally different cooling system. It uses a hydraulic fan and the control system is not the same with USDM's.
I'll be using my USDM ecu, so what sort of bypass for the cooling system would I do?
Currently, to me, it seems like I can simply swap over my USDM components (emission pieces, for ex) and be good to go. So it seems like the biggest problems willl be the "purge" system and cooling?
By "purge system" are you talking about the EGR system (that's what I know it as)?
Regarding the cooling system, I haven't tried that but I think you only need to remove hydraulic related parts and shift the cooling fan with it's attachments.
So long story short, the jdm engine can be done? Im still worried about CA's smog crap, but since it is the same engine (but might not be from the same year as my LS400) and I have a spare USDM engine, I should be good?
Why bother with a JDM swap instead of just sourcing a direct drop in?
Other than compression testing, is there any other possible thing to look out for when getting an engine to determine if it'll run properly?
I like the idea that the jdm ones are instantly ready for pickup and can be compression tested on the spot. I'd really like to go for a USDM engine but I can't seem to find em. Unless Im not looking in the right places.
Check the belt and all seals, I would advise just buying a US engine to avoid the hours of extra labor
e30antonio (06-29-20)
i've only had experience using a JDM engine into my honda and getting it to pass smog. what i essentially did was use the bare long block (head and block) only and swapped over pretty much all the US-spec stuff; even the intake manifold, wiring harness, ECU and other US-only accessories were reused. mechanically i think the 1UZ engines are similar between USDM and JDM, so i would imagine this would work just the same.
