Drivers Window no go!
Hi,
Hope folks can help. I searched for drivers window not moving motor works.... But only found things for the window switch not operating other windows.
1991 Lexus Ls400
Window is stuck down. When I hit the switch windows does not move. I can hear motor turning.
If I try down, same thing.
From LEXLS I know how to take the inside door cover off.
But I need help on what to do with the window not working.
Thank you.
1991 Lexus Ls400
Thank you.
Hi: I'm new here, but hope to help. I found out (by dismantling a parts '92) that the right rear window motor is exactly the same as the driver's door motor. You can swap them out or get a used motor from a scrapyard - which should be cheap, since they usually do not know of this and the RR motor rarely goes bad.
Good luck, J
Good luck, J
TrymyIS
01-28-21 05:13 PM
