1995 Lexus LS400 Blown Fuses for AC Panel
Where is the most common place for a wire short to happen on my 1995 Lexus LS400
fuse keeps popping on the one to my AC panel
blew 2 Fuses today
blew 2 Fuses today
Hello,
The easiest way that I know of to diagnose something like that will be to disconnect everything that is only connected to that fuse, then put it back in and start connecting all the stuff one-by-one until the fuse would pop. If you have a lot of spare fuses, you can disconnect only what you think may be suspicious. Here you can find a chart that shows what is connected to each fuse, that will help you find all the devices connected to the fuse in question. Just remember that it can still be a bad wiring, so if that won't help, you my need to go through it.
Hope this helps and best of luck!
