HELP! Need front camber bolt! 94 LS400
Hello,
First time posting, long time lurker
1994 LS 400 with dreaded LCA bushing sleeve seized to camber bolt. I would cut it off, but as many of you probably know, the camber assembly is out of production!!
This was literally my last bolt to remove, as I am replacing the rack, toe rods, lower ball joints, and LCA bushings.
Is there a replacement option other than OEM? Does anyone have a spare?
Thanks!
Hello,
Thanks!
Hello,
Thanks!
Hello,
Thanks!
You should be able to narrow down a salvage yard that has a 94 LS.
Drewnaj (08-30-20)
Try https://www.car-part.com/index.htm
Update guys.
Salvage yards are not keeping hardware. Can't find the camber bolts that way. However, my local Lexus dealer did track down the last one in the country! Lets hope it pans out!!!
These can be had from different places. I bought mine from our local Toyota dealer but it was a few years ago. Google it.
I have needed to exchange a total of 4 of these. Last I bought was OEM less expensive from JAPAN with nuts and washer etc. AMAYAMA.COM
Rollaboy
09-07-10 06:13 AM
