Ill be honest, there is noo telling when it comes to that. She knew enough to tell me it qas driving funny and that it looked like trans fluid on the ground, after that i took it over
Then the girlfriend is the one who judges if the steering (rack) feels different.
You should determine if the rebuilt unit requires attention..
Rack replaced, powr steering pump replaced. All lexus parts. Now its losing power steering pressure when brakong amd turning and after measuring i can see that it turns alot sharper to the left than right. Then turning right is also tougher than left. What in the world is going on
yeah all that was replaced according to my mechanic, can someone explain the bleed process? Do i really just put it on jacks with the reservoir cap off and turn the wheel vack and forth 50x?
Doesn’t really matter if the res cap is on or off as it’s the low pressure side of the PS system.
50x is prob overkill, it should only take 10 to 12x
