Need help! Bottom of 99 LS motor stopped turning!
Drove LS until March shutdown. It has 368k miles. Let it sit for a couple weeks. When I went to start it, the engine just whined like timing belt was broken. Power to the car seems fine. Mechanic checked it out and said bottom of motor not turning. Motor turns from one side to the other 180 degrees but reaches a point on either side where it stops. Any ideas what would cause this?
First. if timing belt was broken, unlikely the engine would turn 180 degrees in either direction.
Did illustrious mechanic pull a cam cover?
Perhaps battery or starter is tired or expired.
Find another mechanic...
relentLS (11-15-20)
jersey1
15
04-13-03 12:18 PM
