How to turn off "check engine light"?
How can one turn off the check engine light on a "95 LS 400? Yes, yes I know it tells me all soughts of neat things like I need a $1,000 convertor and I need to replace a $500 O2 sensor, etc. but I just want the light off for good. When and if my car runs poorly, I will then decode the ECU and spend some money. Is there a simple way to turn off light where it will not come on ever again???
Forum Administrator
Put a black piece of electrical tape over the light on your dash.
you better get it checked man, dont just ignore the check engeine unless you really know what it is, otherwise it might lead to 2000 dollar repairs rather than the 1000 dollar fix
Just drape a black cloth over the entire instrument cluster,
since you don't care what's happening under the engine, why
bother looking at at the TEMP/SPEEDO/ gauges as well.
This way you can drive until the the car konks out !
Honestly , I can't even think why some one asks that type of question?
Super Moderator
Certain light combinations tell what the problem may be. I would determine what is wrong before eliminating the check engine light.
The other day I removed the intake piping and when I installed it, I neglected to plug in the MAF connector. When I started the engine up, it sputtered and died. When I plugged the connector back in, I got a check engine light that didn't go away after two start-up's. I knew this was a FI error code so I removed the fuse to the FI ECU for about 30 seconds. This cleared it. (I don't know how it is with the main ECU so I don't suggest unplugging that fuse. (Transponder key, engine immobilizer.))
