Variable timing sensor screw size?
98 LS400 Variable timing sensor screw size. I lost it. Does anyone know? https://www.carparts.com/details/Lex...E&gclsrc=aw.ds
Yes that is true, but the driver's side screw is missing and the passenger's side takes more time to take off. I was asking for a size answer. To make it faster. I worked at Autozone..they won't help.
I tried to search it out and came up blank.Im afraid you will probably need to pull the other screw and take it to the hardware store and match it up.
Unsure of length..
Better quality and less expensive to purchase bolt from dealer... a dollar..
Autozone(d) is not recommended.
Walk in, explain what bolt ya need, pay for it, and walk out. Fast and easy.
coolsaber
12-18-20 10:30 AM
