Front fender apron headlamp seals
1995-1997 and 1998-2000 LS400 employ different headlights, thus different seals around headlamps...but noticed gaps on 1999 that do not like.
Located a set of good used seals from 1995 LS400 that I will install to supplement the existing seals on 1999 LS400.
Minor trimming of the plastic frame of seal and a plug and play proposition...
1999 left Headlamp pocket area OEM seal to the far right. 1995 -1997 LS400 use the vertical bar to mount headlamp seal with a single plastic clip.
1995-1997 LS400 seal assembly before very minor trimming with Dremel.
1995-1997 seal installed. No interference with 1999 headlamp assembly and plugs a gap.
Right side installed
Single plastic push clip required.
Parts Diagram for Front Apron Assembly
Will supplement post with images of headlamp assemblies installed..
1999 headlamp assemblies installed with supplemental seals
1999 LS400 headlamp assemblies installed after 1995-1997 LS400 headlamp gasket-shields... Additional gaps are filled.
Perfect fit and no impediments to headlamp installation.
Right side
...and left side.
Right side
...and left side.
FSportBill
01-10-21 09:48 AM
