1998 1999 2000 ls400 HID Ballast removal
Removed 1999 LS400 headlamp assemblies for a project.
Am interested in learning process for removing the ballast assembly...
Notice the HID high voltage cord enters via a through-hole directly from the ballast into the bottom of HID lamp assembly then routed to the bulb.
It is unclear how the HID ballast cord assembly can be removed due to the size of the bulb socket.
Anyone worked this?
Ballast at underside of HID lamp assembly. Cord and lamp socket enters via grommeted through hole
Another angle
The HID bulb socket is quite large and appears too large to clear the internal reflector assembly....
Anyone worked this?
Another angle
Anyone worked this?
Another angle
Anyone worked this?
Another angle
GR3Y5H3ART
06-30-21 02:45 PM
