P1127 - ETCS Actuator Power Source Circuit Malfunction
The code P1127 means that the power supply to the throttle motor is not done. There are two types of no power supply. One is that the line is disconnected due to the open trace or the drive circuit is dead or stopped working. The other is caused by the limp home mode. In this case, something unusual is detected by the processor and the drive circuit is forced to stop by the processor. In order to fix the problem, there needs some more efforts to find out why the motor is not working. If I were there at your garage, I would be able to trace the circuit. It needs some skills to trace the circuit though.
Dealers don't repair ECUs. They just replace it after writing the immobilizer data and charge you some big money. So when you ask them to fix, you need to pay $$$.
You must have done something wrong while replacing capacitors. I am away from you and I can't investigate your ECU board here. At the moment, I only can suggest you to check some more carefully what you have done.
What resistance do you get across the two pins for the throttle clutch? Pins B8 and C12? Mine shows around 3.6M ohms.
There were two capacitors on the list from the ECU thread that I didn't pick the first listed - UHW1H221MPD in place of EEU-FR1H221 and EEU-FC1V331 in place of 35ZLH330MEFC10X12.5.
Technically I also got EKZE500ETC100ME07D instead of EKZE500ELL100ME07D but they just were on tape instead of loose.
I have an idea. If I remove the capacitors one at a time and then recheck the resistance across pins A7 and A8, if that changes significantly, I would think that might give me more information, yes?
Regarding capacitors you used, I think they are OK as far as you installed them correctly. There must be something wrong but it is hard for me to pinpoint the exact part without analyzing the board myself using an oscilloscope, a X-ray machine and others.
While I'm in the process of repairing the original ECM I'm planning to get a spare from eBay and reprogram it to my car/keys. My original ECM is 89661-50434. There are two barcode variants of this - 175200-3130(mine) and 175200-3131. I'm guessing the 3131 is the California emissions variant? Does this barcode number matter so long as the part number matches?
My eventual fix was to get a replacement ebay ECU and swap over my security chip to it. FWIW, it was the 3131 model ECU but so far nothing seems out of the ordinary.
verbatim (04-04-24)
Motorola
01-21-21 09:35 AM
sam12345
32
12-29-12 07:09 AM
InFeRnO87
06-13-11 12:31 PM
MIGS
SC- 1st Gen (1992-2000)
05-19-10 03:13 PM
