Cruise control not working
Old 09-21-03, 12:41 AM
jas400
jas400's Avatar
Default Cruise control not working
My cruise doesnt work,the light on the dash comes on and the cable is still connected at the servo and the TB
I havnt found any blown fuses,is there any tests i can do or does anyone know where the module is for it so i an check the boards ect...
Thanks
Old 09-23-03, 07:04 AM
jas400
jas400's Avatar
N E 1????
Old 09-23-03, 10:28 AM
dunn378
dunn378's Avatar
i have the same problem so id like to know 2!!
Old 08-06-04, 04:03 PM
Buciraco
Buciraco's Avatar
That make 3 of us wanting to know.
Old 01-04-05, 11:02 PM
JoeGS300
JoeGS300's Avatar
make that 4
Old 01-07-05, 08:45 PM
tech237
tech237's Avatar
Just a stab in the dark but.........make sure ALL of your brake lights are working properly..
Old 01-17-05, 04:59 PM
skytrain4
skytrain4's Avatar
I had the same problem on my '90 LS400. After much troubleshooting I discovered the sensor in the brake fluid reservoir was bad. Though the brake fluid level was full, the sensor didn't work, so it caused the brake light to come on. When the brake light is on for any reason, the cruise control is disabled. I disconnected the 2-wire connector that leads to the brake fluid cap, the brake light stayed off, and the cruise control worked. I replaced the brake fluid reservoir cap and fixed the problem. I buy my LS400 parts here: http://www.sportsandimport.com/ since I live in the Atlanta area.
Old 01-27-05, 09:08 AM
tlarrry22
tlarrry22's Avatar
Thanks
Which year?
Does the Drive Indicator Lamp D on the Dash Light up correctly when the Shift Lever is moved?
On my '97, the connecting rod was not aligned correctly. The D Lamp would come on after driving a few miles. Thereafter I could use the Cruise Control. Once the connecting rod from the Shift Lever to the Park Neutral Switch was correctly aligned, the problem went away.
Hope this helps.
Emilio253
SC- 1st Gen (1992-2000)
08-04-10 12:15 PM
sssjumper
11-01-09 08:06 PM
stromer
Suspension and Brakes
05-11-08 09:56 PM
5ofakind
06-06-06 09:00 PM
tuterz
09-14-03 05:58 PM
Quick Reply: Cruise control not working
