1990 lexus chrome quality?
So I’ve been thinking about doing some engraving onto my chrome grille in my 90 ls400 but as I’ve been doing research it seems like in order to get a good engraving the chrome has to be high quality and have high copper content or else the chrome will start peeling would anyone here by chance know the quality of the chrome on the first gen ls400s? I wouldn’t want to engrave it and end up having a destroyed grille
See:
https://en.m.wikipedia.org/wiki/Chrome_plating
Chrome is short for Element Chromium...so Copper is sometimes an underplate....
See:
See:
ohh i see so do you think the chrome grilles on a ls400 would be able to be engraved on without the chrome peeling off? Or do you think it’d be too risky
First, Chrome is incredibly hard, so it's going to require an incredibly hard bit and very steady hand.
Second, Chrome plating, as the name implies, is a micro-thin layer of Chromium is deposited on the casting through electro-plating.not a solid piece of Chromium here.
So when you engrave, are going to cut through the thin layer of Chromium and its gonna look like _____t.
Provided the Chrome plating does not chip, it could work if the part is chromed after engraving...but no reputable plating shop will want to be involved
Better to apply an overlay with what you want to say...or get vanity license plates.
The Grille element on my 1999 LS400 is unplated plastic...
The only metallic component on 1999 that could engrave is the surround....
Is OP suggesting to engrave the plastic grille element in some fashion?
The grille surround on 1999 LS400 sure appears to be a heavy chrome plated casting
Last time I checked, all LS 400 grilles (and LS 430, etc) are plastic with chrome plated frames/surrounds. I don't think the chrome plating is thick enough to withstand engraving.
From what I understand, OP wants to engrave the chrome surround/frame, not the mesh/element.
