94 LS400 alarm going off
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Hi all, I have recently purchased a 1994 LS400 and it came with a key without a transporter in it so quite often when I unlock it the alarm will go off which is very annoying. I have gone through a lot of the old threads but a lot of them just talk about resetting the alarm unit with the key that I don't have, or something to do with grounding a green wire in the kick panel, but I couldn't find it. So I was wondering, does anyone have a good work around to either disable or remove the alarm unit or even just stop the damn beeping till i can get it properly fixed. Thanks all.
I'm here with this same problem 1995 LX400. Starting 2 weeks ago when I unlick the driver door my alarm beeps once. It then finds the key and gets quiet. This started happening after the driver door lock froze and I used WD40 to free it. The passenger door works fine. I do have the fob (somewhere).
davids2k
11-25-12 07:54 PM
ttyR2
09-17-09 06:29 PM
