Where did I go wrong -MPX body & ABS VSC module
Old 03-03-21, 07:36 PM
99ls400gg
99ls400gg's Avatar
Default Where did I go wrong -MPX body & ABS VSC module
Current MPX body 89221-50110 and ABS VSC control module 89541-50110 in car both work, recently bought these two part identical item from junk yard for spare but after install, vsc check engine light came on, disconnect battery, still same.
Took me out and put old parts back, now still those light won’t go off.
pretty sure no mechanical problem with car as before swapping no light on.
any input?
Old 03-03-21, 08:08 PM
Received 2,908 Likes on 2,453 Posts
Need to read the code(s) first and go from there.
Old 03-03-21, 08:12 PM
99ls400gg
99ls400gg's Avatar
Default Code reading process
Now the fun part, decoding lol, will update when code becomes available
Old 03-03-21, 08:15 PM
Maybe the multiplex module needs to be synced to the car?
Old 03-03-21, 08:38 PM
99ls400gg
99ls400gg's Avatar
I switched back to my original multiplx and the light is still on
Old 03-03-21, 09:01 PM
Yamae
Yamae's Avatar
The multiplex module does not need to be synced. Does the dome light and door locks work properly?
If so, I'd try to remove the battery's negative terminal for 10 minutes and connect it.
Old 03-03-21, 09:08 PM
99ls400gg
99ls400gg's Avatar
Light all work, remote lock unlock stopped working long ago this problem
only problem after switching back and forth these two parts just a vsc and check engine light remain on. Did not happen prior to the switch
Old 03-03-21, 09:12 PM
99ls400gg
99ls400gg's Avatar
Jus to make sure I make it clear, I changed those junk yard parts (same part number as the existing one in car to test make sure seller did not sell me stud)
prior to the swab, the car runs normal with no warning light whatsoever on dash. Only thing did not work was the remote lock.
now adding to problem is the new vsc and check engine light remain on.
thats what I do not get is that even after I put the two original parts back into where I took them out, those lights still remain on.
Old 03-03-21, 09:16 PM
99ls400gg
99ls400gg's Avatar
And I have tried to disconnect the battery for one whole night, lights still on
Old 03-03-21, 09:17 PM
99ls400gg
99ls400gg's Avatar
My babe only has 68k miles
Old 03-04-21, 03:13 AM
99ls400gg
99ls400gg's Avatar
Here is what I removed and installed all same part number
Old 03-04-21, 05:21 PM
Bylan
Bylan's Avatar
Buy a cheap OBDII reader to your tool collection, ELM327 is less than $10 and get the Torque app on your phone. Can do lots for very little, only way you're going to know whats going on is to read the codes.
Old 03-04-21, 05:34 PM
99ls400gg
99ls400gg's Avatar
Old 03-04-21, 05:36 PM
99ls400gg
99ls400gg's Avatar
Old 03-04-21, 05:48 PM
99ls400gg
99ls400gg's Avatar
Tried erase code, still can’t make code go away,
Quick Reply: Where did I go wrong -MPX body & ABS VSC module
