Ls400 starting issue when interior is warm
When the car is cold, it will start right up first crank no problem. But if it has been driven for anything more than 5 minutes, it almost always takes two cranks to start up. And by that I mean the first time I start it itll fire then shut off after a second, then I can hold it there as long as I want continually cranking and it will never catch or even act like its starting. But as soon as I quit cranking it, wait a second, then start cranking again, it will start right up! If I press the gas pedal a little bit itll roar to life. After it starts its a champ.
I changed both coolant sensors, the fuel filter, checked fuel pressure, changed plugs (did had same condition before change, also since it needed it), checked spark also hear for fuel pump. But I did this when it was cool inside the car. Temps here have been around 34 to 50 recently went up to 80. Now its back down to 50. Thats when the interior is warm and when it happens.
I suspect fuel pump. Any thoughts?
I dont know if its the OG. But unlike most on it I dont know if or ever its been replaced. Might as well.
Beg to differ Superfast! I replaced my fuel pump already and although, like you said, it's relatively easy to get to, removing it is a rare pain in the ***. You got this 2" or 21/2" piece of rubber tubing right above it that attaches to the pump outlet line that I have found to be very difficult to impossible to remove in order to get the pump and bracket out. This is for my Lexus which is a 1992/93.
The solution which worked fine for me, was to completely sever the rubber tubing with a sharp utility knife or box cutter which then made extracting the whole assy, a breeze. Of course you need to make sure you have replacement tubing on hand before you start so you wouldn't have to go shopping for one. Also be careful when you are loosening the two tubing clamps so they wouldn't fall into the tank. Oh yeah, and finally you would probably have to cut the electrical connections to the pump (remember to disconnect the battery before you start!) in such a way that you would be able to re-join them later. Other than those things it really not all that hard.
Sin1UZFE (03-10-21)
Fuel pump replaced. Resolved the issue. Got to 85 today so I parked in sun car was toasty inside. Has not done it again
Sin1UZFE (03-24-21)
