Rear Coolant Bypass
Rear Coolant Bypass
Whats the part number, or size of the nut that secures the rear coolant bypass pipe to the block?
Replacing my starter, got the new one installed and im stuck at re-installing the bypass due to one of the nuts free spinning and i need to be able to torque it down. Thanks for the help.
So. Starter is in and your reinstalling the crossover bridge ( egr cooling bridge)?? Crossover pipe you mention...do you egr tube ??
I’m in the middle of starter job and cleaning manifolds ...I’m right there with you
