Strut Rod Removal Issue
10th Gear
It's the original strut rod, and after 22 years it just don't want to come out! I removed the three nuts: the big one on the mounting bolt and the two smaller ones attached to the arm and removed the arm from the axle. But the through-bolt will NOT BUDGE! I think maybe it is rusted to the inside of the hub. When I tried to turn it(unscrew the bolt head in case it was still screwed into something), the whole arm moved with it. Any ideas? I just have a propane torch, no acetylene, but maybe I need to heat up the hub.
It’s rusted to the inner bushing sleeve. Order a new bolt and bust out the sawzall.
yes, cutting through the bolt on either side of the bushing is your only option. I had to do this to all 6 of my bolts going through the bushings in the rear end in order to do an alignment using the eccentric bolts in the back attached to the subframe.
I think I went through 6 sawzall blades.
mandyfig
11-04-17 06:06 AM
