Leaking Coolant from Engine Block
Hello!
I recently became the new owner of a 1999 LS400. The starter was not working properly so I rolled up my sleeves and got to work replacing the starter, valve cover gaskets (small oil leak), spark plugs and new gaskets for everything I replaced relating to the starter. I also did an oil and coolant change. I noticed a coolant leak on the side of my engine when looking underneath after starting up the car with the new starter. I recorded where the leak is coming from and it seems to come from a black plug on the underside of my engine block, on the passenger side of the car. It does not seem to be coming from any coolant hoses. I was wondering if you guys have any clue what the black plug is and where I can start to replace it. Thank you.
Pic is a bit fuzzy...
Is it a drain petcock? YODA just did a thread a few days ago- https://www.clublexus.com/forums/ls-...ain-*****.html
rkw77080
10-18-23 02:44 PM
Bociba
11-24-10 02:51 PM
