Hi, I have a mint 1995 Toyota Celsior that I've been trying to put a double din stereo in. I was following this guide which worked perfectly when I had a 95 ls400, but the celsior wiring is completely different.
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/857222-1995-1997-ls400-aftermarket-radio-install-utilizing-stock-amplifier-for-pioneer-radio.html
I have attached pictures of the plugs and the back of the stereo. Does anyone have a diagram or know which wires are for what? I'm hoping to findt all the speaker + and - wires as well as amp on, ground, acc, constant, illumination, and power antenna.
Don't cut, remove all the pins and clip them back in to match the stereo you are installing. Why would you disregard the colours? They are mostly universal for Lexus/Toyota especially speaker wire, ground, power and accessory. For power you can easily figure those out with a test light.
