93 LS400 dies unless pressing gas after fuel pump change
The car had been sitting for a while (2 years) because of a cracked egr pipe, replaced it and wouldn't start
then replaced the fuel pump (the strainer basket was in pieces)
Now when I jump it it cranks and starts then dies unless I give it gas, no check engine light at all.
Went to clean the IAC and realized while pulling it off that it isn't the kind you can clean (watched a vid on an older model 1uz and thought it was the same).
Any ideas on what to check before I pull it out and try to find a replacement in a junk yard.
Thanks for any suggestions
lex8000
08-30-13 10:31 PM
