New Owner, First Troubles
I’m hoping someone can help me out here. I recently purchased a 97 ls400 and it ran great then I noticed an oil leak, and my engine light code said my car was misfiring, so after research decided to attack the valve cover gasket first. Well while I took this apart I noticed oil over my spark plug lines and decided I better clean them and fix the leak before replacing them. I put my engine back together, accidentally spilling some brake fluid when I detached a line, oops. Well now everything is back together but my engine starts then gurgles (maybe it’s knocking?) don’t know a better word for it. Should I reclean the spark plugs as I only removed the oil and didn’t deep clean or try something else?
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/626x382/d8c9b174_ff32_4ca1_9e6a_88e4fc4f4073_aa42532a47cf3c38d30924b703ee348dfbf7ec45.gif)
cleaned the ignition wires deeply this time but still didn’t like the sound without the MAF plugged in. Maybe this can help diagnose the issue? It sounds like something is scraping? I don’t want to keep running the engine until I get something solid
after fixing the valve cover it seems it was not the cause of the leak in the first place so I’ll probably do the cam shaft ASAP since my timing belt has some oil on it now.
Definite bearing scraping. I can hear it most in the 3rd video. Could be any one of your pulleys but it looks to me like your fan is wobbling a little. Also sounds like an exhaust leak towards the right side rear of engine. (EGR pipe maybe)
In the 2nd video sounds like air leaking from the air intake pipe where you have all the junctions globbed together. Don't know who did that or why but the vacuum line coming from the drivers side isn't even supposed to go there. Everyone I've seen goes directly into the front of the intake manifold, yours has a cap there.
BlKTC
03-06-17 08:42 PM
