rotted brake lines
rotted brake lines
I had a rear brake line rot out (along with half the rear of the car) and I had someone cut it and fix it. Well, as they were bleeding the brakes the same line sprung another leak. I was wondering, (as a temporary fix) is there a way I can plug the rear brakes, like maybe at the master cylinder, so no fluid goes to the rear. I only drive maybe 2-3 miles a day now and I am looking for another car anyway. So I would like to plug it so I can get maybe a few more weeks out of the car. It's not worth changing the line from front to back.
Few see brake fluid as necessary maintenance.
In your case, if one line was replaced and another immediately ruptures portends an accident waiting to happen.
All brake lines should be replaced.
Do not accept advice on how to
band aide an unsafe braking system.
sha4000 (09-18-21)
The entire hard line needs to be replaced. Depending on the production date of your car, some of the lines might still be available from Toyota. There might be a shop someplace near you that can fab up a line using the original as a pattern.
Oh well, looks like I gotta get off my *** and find another car. As some people here know, this frame is rotted and alot of other stuff bad. I have driven with brakes alot worse then this for many miles.....but I was young and dumb then.
whoa! sorry to hear. i'm sure you can plug the line somewhere at the ABS module or just cap it up the stream where there is least corrosion (for a short term fix of course).
best wishes to get you going again, and if you replace the car entirely, to find you in another LS!
Thanks Mike for the advice but to everyone else that is gonna say "it shouldn't be driven", I know that.
It's not like I drive on a NASCAR road course or I'm some kid that just got a license, I've driven a heck of alot worse vehicles in worse situations for alot longer time and distance. To me it's still drivable, just by adding fluid. It's only a pin hole where it's rotted so it's not like it's guzzling out, but it would be better if the line was blocked somehow cuz of the other rust on the line.
Yesterday I went to one of the major "muffler and brake" chain stores (I won't mention which one) and they said they want $700 to run two new lines to the front. That's outrageous. I'm not gonna take that out of my new (used) car money.
timmy0tool (09-17-21)
yes, only to get the car positioned for further repair. i'm sure dean is fully aware of the ramifications driving on public roads.
we've all driven on flat tires; i always tell my wife do not pull over on the highway as much as you can help it for your safety. drive on the flat tire and ruin the rim if it gets you out of harm's way!
