Removing Rear Subframe
Old 09-18-21, 10:46 PM
StaticMatt
StaticMatt's Avatar
Default Removing Rear Subframe
I have a 2000 ls400, very low and I’m putting in a new rear subframe to raise the differential to go lower. After disconnecting everything from the rear end, the only wall I hit is that the front differential/ subframe bolts are loose but won’t come out (they are not free spinning)
I circled the bolt giving me a problem
Old 09-18-21, 11:00 PM
Received 3,022 Likes on 2,538 Posts
By free spinning you mean the captive nut? That is not spinning in the frame? What happens if you try and tighten the bolts.
Old 09-18-21, 11:09 PM
StaticMatt
StaticMatt's Avatar
Captive nut? What do you mean? If I try to tighten or loosen the bolt it gets too tight to move.
Old 09-18-21, 11:32 PM
The bolt threads into something, often that will a nut inside a boxed piece of steel or welded to the frame. Captive means the nut is not designed to be removed.
Oh a seized bolt. Classic problem hit it with penetrating oil many times over the course of hours or even days. If that fails heat the bolt.
Old 09-19-21, 11:31 AM
StaticMatt
StaticMatt's Avatar
It might be captive, I’m gonna just cut it off and replace the bolt
YODAONE
11-02-21 07:55 AM
YODAONE
02-14-19 07:06 PM
Vansibel
04-03-18 09:39 AM
soaringlex
Performance & Maintenance
12-20-13 11:19 AM
Quick Reply: Removing Rear Subframe
