Running Light condensation?
What do you mean by shell? The lens?
Please share more photos of the corner light and photos of the backside of with the bulb plugged in and with the bulb out.
From the photo you posted, it looks like the bottom right of this lens is cracked, which could be where moisture is getting in.
Moisture will get in if the bulb socket is damaged or the seal is broken or of the corner lamp assembly has damage on the housing or lens in the form of a crack or a hole.
