LS430 CD "Fast Forward"?
Old 10-02-03, 01:07 PM
daryll40
daryll40's Avatar
Default LS430 CD "Fast Forward"?
Where is the "fast forward" for the base CD changer in my '03 LS430? I can't find it anywhere. You know...for when you want to fast forward thru a slow part of a song to a better part of the same song?
Old 10-02-03, 06:38 PM
lexusls430
lexusls430's Avatar
Hello you need to go to push the audio button located on the right of the navigation system and when you enter you willl see two buttons one like this ^ and one pointing down touch and hold the arrow up to fast foward and the arrow down to go back.
Old 10-02-03, 07:54 PM
daryll40
daryll40's Avatar
I don't HAVE the navigation system. Now what?
Old 10-02-03, 07:56 PM
lexusls430
lexusls430's Avatar
ILL find out tommorow and let you know ok
Old 10-03-03, 04:54 AM
daryll40
daryll40's Avatar
Thanks. I await your answer.
Old 10-05-03, 03:46 PM
daryll40
daryll40's Avatar
Lexus LS430, what did you find out?
Old 10-05-03, 04:52 PM
AsianGirl007
Lexus Diva
AsianGirl007's Avatar
While you are playing the disc, you know where the preset is numbered 1 thru 6? While you are playing the cd's, there are some instructions that appear above the 1-6 buttons. I'm not sure of the exact order, but it goes something like: disc up, disc down, fast forward, rewind, repeat, and random. The icons with the < and > are fast forward and rewind. I hope this helps.
Old 10-05-03, 05:41 PM
daryll40
daryll40's Avatar
Nope! That's how it worked in the '02 ES that I traded in. My LS does not have ANY < and/or> arrows. It does have up and down arrows for next CD but nothing for fast forward or rewind. Did you SPECIFICALLY get into an '03 LS without the Nav and check it? Or am I crazy?
Daryll40
Old 10-05-03, 05:46 PM
AsianGirl007
Lexus Diva
Question What the....????
No, I did it from memory. (okay, so sue me, I took a shortcut) I'll go check now.......I need to get a cd from my car first otherwise it won't light up into cd mode.
Okay, you are NOT crazy. the #3 and #4 are blank, which is pretty much where the forward/rewind is on the other cars. That's really weird. I never noticed that before.
Old 10-05-03, 05:52 PM
daryll40
daryll40's Avatar
I didn't mean to bust your chops. I just suspected that you were guessing because I did everything and can't find it. In the end, it would appear to me that there is NO FF or REWIND for the CD without NAV. That really sucks! How could Lexus make a goof like that?
Old 10-05-03, 05:59 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
That's the exact same thing I'm wondering. On the Nakamichi system in my '91 LS...there's a FF button, but no REW button for the CD player.
Old 10-05-03, 07:25 PM
vraa
CL Folding Team Starter
vraa's Avatar
My 94 w/ Nak doesn't have FF OR REW!!
Old 10-05-03, 08:53 PM
darchtop
darchtop's Avatar
On some systems (not sure about this one), you hold down the button that advances you to the next or previous CD track. This will often give you the effect of fast forwarding or rewinding through a CD track.
It might be worth a try.
Old 10-06-03, 04:46 AM
daryll40
daryll40's Avatar
If you do that, it advances to the next track! Now that more fast forward than I want!
Old 10-06-03, 06:13 AM
jcolegrove
jcolegrove's Avatar
hi,
same problem with my 93 ls. no REW button with NAk system. how could this be with these cars? surely someone knows something, somewhere...
JC
Quick Reply: LS430 CD "Fast Forward"?
