Replacing Suspension Bushings
Pretty much my whole suspension needs replacement bushing and i cant seem to find any replacement kits. Only new assemblies. Anyone know where i could find new bushings if they still exists?
There is no actual "kit" that I know of that has everything. I'm pretty sure you need to buy most of the bushings separately. Try not to buy poly bushings cuz they squeak. Just my .02. If you need new bushings in the upper control arms ya might as well buy the whole arm cuz the ball joint in the UCA is not changeable.
You'll probably find info you need by using the search; https://www.clublexus.com/forums/sea...rchid=24789818
And also the FAQ; https://www.clublexus.com/forums/ls-...questions.html
What year is your LS and how many miles?
Deegee
Suspension and Brakes
08-22-15 04:24 AM
