Intermittent climate control panel problem
7th Gear
Hello, my 1997 LS 400 developed an intermittent problem with the climate control panel. I purchased the car a month ago and the problem suddenly came up this week.
THE PROBLEM -
Usually when I start the car, some of the climate control panel buttons and functions do not work. However, after 1-2 minutes of driving (or idling), everything works and it keeps working fine. Until.... I shut the car off. Then usually the problem re-appears, and then again after 1-2 minutes it disappears.
THE BUTTONS and FUNCTIONS THAT INTERMITTENTLY STOP WORKING -
- Temperature "down" on the driver side only. (On passenger side, it works, but only in DUAL mode)
- Rear defrost does not come on
- Mode button does not work
- Front defrost works, but the fan control does not work with front defrost on
- Other things don't work either, but I would have to experiment more to know.
I ran the diagnostics by pressing Auto+Recirc and starting the engine, and the only two codes are 21 (the solar sensor, which is not a concern) and 24 (which I do not see on any lists of diagnostic codes). For BOTH codes there is a beep which I understand means the problem no longer is happening.
After being a problem for 1-2 minutes after starting the engine, suddenly it will go away and everything works again.
One thing that might be a coincidence is that earlier I did remove the center console cover to repair the front and rear cigarette lighter/charging port, and this involved un-plugging some connections that might have been on the same harness as the climate control and stereo. Maybe I loosened a connection up behind the climate control panel?
Has anyone seen this problem and fixed it? Also, does anyone know what error code 24 means?
Thanks!
THE PROBLEM -
Thanks!
THE PROBLEM -
Thanks!
THE PROBLEM -
Thanks!
Regarding the problem which only happens for 1-2 minutes after the car is started up, it is a typical symptom of a failing DC-DC converter in the climate control unit. I'd check the DC voltage and the ripple voltage level using an oscilloscope for the confirmation. Another simple method is to use a hair dryer. Warm up the climate control unit until the inside of it reaches 100 degrees F+ and start the engine. If the unit works fine right after the starting up, electrolytic capacitors used at the DC-DC converter circuit should be replaced.
